Danni Nissan Skyline R32 Stroker '90
Discussion in 'Lugejate autod' started by dannukas, Jun 17, 2015.
  1. dannukas
    dannukas Active Member
    1,044
    Eelnev autoteema leidis jube kiirelt lõpu, kui sain cabrio vaid 8 tunniga müüdud. See tuli endalegi üllatuseks. Igatahes sai vahepeal omatud täiesti tavalist autot, kuid hing ihkas ikka taaskord midagi pilkupüüdvamat ja vähe eksootilisemat, seega sai selline sõiduk ostetud. Dokumentides on auto kirjas GT-R'ina ning turvapuur ja kõik muud modifikatsioonid on ka seadusega kooskõlas.
    Spec list :
    Footwork:
    Super pro steering rack bushes
    Tein steering rods and ends
    Driftworks rack spacers
    Driftworks solid steering bush
    Driftworks solid diff bushes
    Driftworks solid subframe bushes
    Driftworks polybushed rear lower arms
    Driftworks polybushed front r33 lower arms
    Driftworks rear camber arms
    Driftworks toe arms
    Driftworks traction arms
    Driftworks Hicas lockout kit
    Driftworks CS2 coilovers with new uprated bottom bushes
    Driftworks front camber arms
    Driftworks tension rods
    Cusco front strut brace
    CUsco rear strut brace
    Cusco 6 point cage with diaganol
    Nismo oil cap
    Nismo engine mounts
    Ultralite 20mm bolt on hubcentric spacers front
    EBC rear brake discs
    EBC rear brake pads
    Mtec 360mm drilled and grooved front discs
    Brembo 6 pot front calipers
    Mintex pro race front pads
    Engine:
    Tomei 2.2 stroker kit
    Tomei forged pistons
    Tomei fuel pump
    Tomei metal head gasket
    Tomei oil pump
    ACL race bearings
    R33 turbo
    Braided turbo oil and water feeds
    Braided fuel lines
    Braided breather hoses
    stainlesss divorced turbo elbow
    Apexi exhaust
    XS power fmic with hard pipe kit and new joiners
    Greddy spark plugs
    Greddy sandwich plate
    Greddy water hose temp adapter
    Greddy oil filter
    Blitz metal air filter
    Custom made ally catch tank
    ORC single plate (unconfirmed but seriously heavy duty!)
    Driftworks radiator
    Driftworks rad cap
    SFS silicone rad hoses
    Custom Black roose motorsport silicon joiners throughout engine bay
    Garage defend slam panel
    z32 fuel filter
    Rising sun custom mapped ecu
    INTERIOR:
    Sparco steering wheel
    Nismo shifter
    Cusco programable shift light
    Driftworks snap off hub
    Driftworks hydraulic handbrake
    Driftworks Hydraulic hbrake lines
    Greddy Profec B II boost contoller
    Greddy Turbo timer
    Greddy 60mm warning boost gauge
    Greddy 60mm warning oil press gauge
    Greddy 60mm warning water temp gauge
    Triple gauge holder (super rare expensive jdm item)
    Fia cage padding
    stock handbrake removed
    GTR doorcards
    GTR rear seats
    GTR driver seat
    GTR passenger seat
    GTR mats
    Plasma glow aftermarket dials
    Toad cat 1 alarm/immobiliser
    Battery box
    Fire extuingisher
    JDM carbon pedal covers
    Broadway wide rear view mirror
    Pioneer avh 3200bt headunit
    Alpine 6 inch rear speakers
    Alpine 6x9 front speakers
    Rims:
    17x10 et10 all round
    Exterior:
    Carbon wind deflectors
    Carbon Nismo bonnet
    Carbon Nismo n1 bonnet lip
    Carbon Dmax roof spoiler
    Bomex wing mirrors
    Vertex side skirts
    Greddy Rear spats
    GTR front arches
    GTR front indicators
    GTR front headlights
    GTR front grille
    GTR front bumper
    GTR front splitter
    GTR N1 vents
    GTR rear spoiler
    GTR rear overfenders
    Aerocatches on bonnet
    Rear over fasteners on boot
    Led number plate lights
    Led reverse lights
    Led sidelights
    Led interior lights
    HID headlights
    Battery relocated to boot
    Washer bag relocated
    Toomine:
    Eelmise omaniku pildid:
    Ja kõige tähtsam:
    Plaanidest nii palju, et just tellisin uue samasuguse jooksu kärgvelgi tagavaraks, varsti jõuab kohale uus Exedy 6-puck heavy duty sidur jpm. Hetkel mingit valmimisaega ei suuda öelda, kuid augustiks peab auto juba perfect olema.
    Dan
  2. Ivan
    Mis sellega tegema hakkad? Uus driftiäss tulemas? :p
    Muidu auto on vägev, tuult tiibadesse!
  3. 426f
    426f Member
    514
    rool on valel pool
  4. xxm24
    kle seda panid ikka tähele, et rool valel pool ostes? :lol:
    ei päris vaarikas, maasikas veel ei ole :D edu! saksalane japsi vastu
  5. dannukas
    1,044
    JDM pillile kohaselt on ju rool täiesti õigel pool
    Veel pole liiga hilja alustamiseks jah 8)
  6. henryx698
    henryx698 Active Member
    1,468
    Peaks mainima, et eriti hea diiliga saadud kh :p
    Suuri kulutusi ja edu siis sulle! :D
    Hen
  7. stennucpi
    stennucpi Member
    221
    Mõttetu ront
  8. Mihhailov
    Mihhailov Member
    260
    sama
  9. 426f
    426f Member
    514
    vale foorum ka
  10. dannukas
    1,044
    Ega muudes foorumites nii väga edu ei soovita, nagu seda tehakse rk's. Just seetõttu on see teema siin ja mitte kuskil turboclubis või driftime foorumis.
  11. TUUR
    1,138
    10
    300 hobust ei tohiks mingi mure olla vända otsast.
    Ilus kaa teine lisaks.
  12. sector
    sector Member
    427
    krt kuidas tahaks endale ka ühte skyline. need r32 suht hinnas ka juba.speclist ka päris kõva. on maksta :D Ja kui saladus pole siis kus kaugelt tõid? muidu sigakena ja vägev pill. palju edu ja kestvaid rehve!
  13. jaanjou
    jaanjou New Member
    77
    Kui ma ei eksi siis masin tuli Tallinnast :p
  14. henryx698
    1,468
    Tallinnast jep.
  15. vladusik
    vladusik Active Member
    2,358
    Tuttaval Tallinnas kah olemas selline aga too on Tommy Kaira edit.
    Edu ja paksu rahakotti 8)
  16. dannukas
    1,044
    Auto läheb homme värvimisse. Lasen teha seal kus ka cabrio ära värviti. Muidu mingi hetk sain veljed kätte. Kõik 10" laiad ning 225 F1ed venitati vabalt peale.
  17. xxm24
    Miks värvimisse, vana värv ei kõlvanud? Palju muidu suurus järgus siukeste velje hind on?
  18. dannukas
    1,044
    Perfect peab olema. Seetõttu läheb ka mingi hetk puur värvimisse, kapoti all kõik alumiiniumdetailid pollib üle jnejne. Kõik selleks, et lõpus oleks mida vaadata.
    Velgede kohta kirjutasin ps'i.
  19. sector
    sector Member
    427
    mis sul selle autoga plaanis on siis, driftiks, niisama või lihtsalt "näitusemasinaks"? :D
  20. dannukas
    1,044
    Näitusemasinat sellest siiski ei saa. Kuna see on algselt ehitatud drifti eesmärgil, siis driftikaks see ka jääb. Plaan teha see lihtsalt võimalikult viisakaks ja korralikuks, et ise rahul oleks. Seega jah, sellest saab "niisama" auto, mis on silmale ilus ja vajadusel piisavalt nobe, et minipiffide ees eputada.
